Low top end speed 4.3lx?
Dillle209
hey so i have a 1996 Larson 174 sei with a 4.3lx with 400 hours with a 19 prop and i can only reach about 35 at 4200 rpm i can go higher on rpms i just don’t like to wot .is this a normal speed at such a high rpm ?
Your motor can do WOT and this is the only way to know if your propped correctly. You should be able to get between 4400-4800 rpm
you need to test WOT with the throttle mashed against the stops.
this is normal and you can run the motor there for a short period of time to test your top speed.
jimmbo
What gear ratio does your engine have?
You have to prop it so it runs within its recommended rpm range at WOT, not because you want to go run a certain RPM at a certain MPH.
A 17 ft boat with a 4.3 should see around 45-48 mph at WOT
