Ok I have a 1988 bayliner trophy. Problem is I have very low voltage at idle, and when motor is wide open only at 13v on the dash meter. when I slow down voltage drops. If i turn the key on its at or below 10v
Problems having:
Trim tabs not moving
Engine wants to cut out when trying to trim outdrive up or down
when trimming or trying to use trim tabs voltage drops below 10 then comes back up when you let off the button.
Pulled the altenator off tonight going to have it tested in the morning. Any other problems you guys might think it is?? Thanks
Problems having:
