I have a question regarding the electrical side of a 1982 40 hp Mercury -
First off, the motor has been pretty much gone through already and is running pretty good for being 30 years old. The stator and trigger both check out good for resistance and DVA voltage. The switchbox is new, because the old one seemed to be bad by process of elimation. By the way replacing the switchbox did fix the idling and power issue. Both old coils check out good for resistance, however one had a good amount of oxidation internally so it was replaced with a new one.
Now with everything else checking out good i am still only showing ~2.5 volts on both coils from the new switchbox, this is checking at the switch and at the coil. The spec for this system is ~150v using a DVA. This was also the case with the old switchbox.
What i really dont understand is how i have a good spark, the engine starts quickly and runs good but is getting such a low voltage between the switch and coil. I know the DVA works and is accurate, as i can pull good readings from the other components. I have also pulled readings to the coil while the engine is running, turning over, and plug wires disconnected all with the same result.
So does anyone have any ideas or am i a dumb@#$ and doing something completely wrong?
