Low Volts
truax42
my 89 120 evinrude will only read 11.5 to 12.5 volts while running (acording to in-dash volt meter). i have yet to have a battery go dead but this does concern me a little. any tips?
ob
Re: Low Volts
Your engines reg /rec is either not putting out or the volt guage is not working.Worst case scenario is the stator winding .If equipped ,does the engines tach seem to be working?
truax42
Re: Low Volts
yes, the tach is working fine, both batteries are new also
Marc J.
Re: Low Volts
I'd double check the voltage reading (at the battery terminals)with a multi-meter as a start. I got a nice little digital one at Radio Shack for $20. You should be in the 13-15v range while running.
