Touch of Madness
- Joined
- Aug 29, 2006
- 14
I have twin MY 2000, 5.0L Volvo Penta engines with duo-props. Ever since the end of last season, I've lost 800 rpm off WOT on both engines. My fuel consumption has also increased from 17gph (at cruise) to almost 25gph and I don't have as much power getting on plane. I pulled the plugs from both engines and they were all wet so I suspected spark issues. I replaced the plugs, plug wires, distributor caps, rotors, fuel filters and ignition coils. My TechMate scan tool said I had a bad map sensor on one engine which I replaced. I took the boat out after all the replacements and cleared diagnostic codes to find that I still have the same problem. Came back to dock, checked diagnostic codes and they weren't any. Boat runs fine...no knocks, sputters, etc. Any other things I should check? What ever it is seems to be affecting both engines.
