jasunderland
- Joined
- Jun 2, 2011
- 16
Is there a trick to removing this without the tool or do I need the tool? I'm trying to remove the drive shaft to see if it is pitted badly because I'm getting water in my oil with minimal running. I checked the drain and vent plugs already.
The manual says I need to remove the bearing carrier and propeller shaft to remove the drive shaft but I'm stuck on how to remove the cover nut without a tool. I've tried heat and I have it soaking in penetrating oil. I've tried a punch and hammer but it is dinging up the nut and not budging.
