Lower crankshaft seal
Keith Buchanan
50HP 3 Cyl 1989<br /><br />Hi Guys,<br /><br />Any ideas what is involved with the removal and replacement of this fella.<br /><br />Regards Keith B...
Kiekhaeferscurse
Re: Lower crankshaft seal
Pop The power head, remove end cap bolts gently pry out endcap, if it doesnt move at all, your going to have to split the cases, pry gently you can also try loosing a couple of the lowere case bolts
Keith Buchanan
Cheers Mate, doesn't sound to much of a nightmare.<br /><br />Regards Keith B......
Kiekhaeferscurse
Hi Keith<br />If that lower seal is knackered, you will most likely get water into your cylinders, causing a misfire on sparkplugs also it tends to wash away the oil lubricating the cylinders, many a destroyed engine out there thanks to that lowere seal....good luck
Clams Canino
Also try rotating it a bit before prying anything. - there is a puller for that if you wanna do it right too. :) <br /><br />-W
