Re: Lower End dry as a bone!!!! Help!!
well at least you know the seller was not trying to hide stuff on the test run
I took my NEW motor in for a skeg replacement and they did not put oil in it. Ran it for a couple of outing before realizing this so I feel you pain and angst. That was 3 years ago and no problems for me yet....it did cause concern for sometime and I now wish I did not fret so much.
water can be drawn in or oil can be pushed out.
some (all) oil will have a yellowish appearance after being agitated so dont fret that. What you want to be looking for is a milky streak. Make sure the seals are replaced for the oil screws as they can let water in.
So: take it out for a couple of runs, take it easy, see if it needs topped off and how much then drain it and check for metal and water contamination. Repeat this once if you see metal (it could have been there from before) and then get back to the forum with the findings.
If you have water contamination they will pressure/vacuum test it. You might need seals and when it is opened up they will check out the gears for damage. No sense wonder about he amount of seals that need replaced...they will replace all of them....it is the labor that is the pain.
Also contact the person you bought it from....there might be a simple explanation that will take your worries down a notch or two (like he just had the skeg serviced).
good luck
nn
