lower end gear oil
pauldog
hi everyone what is the recomended gear oil for the lower end of my 1952 evinrude twinlight 3 hp can i use the same oil in my 80s sea king 7.5 any tips on draining and replacing would be greatly apreciated thanks for any info pauldog
oldcatamount
Re: lower end gear oil
Make sure you get gear oil that's desined for outboard lower units. Any brand will work, just get a quality name brand. As for draining the old oil, take out the upper and lower screws and catch the old oil in a can. When you put the new oil in, let some run straight through so it will rinse out any sludge. You will need two new seals for the drain/fill screws.
bktheking
Direct drive or forward only outboards generally use Lubriplate 105 white grease or corn head grease which is sold at tractor supply outfits.
