LOWER OIL RINGS
proline
HELLO ALL. I OWN TWIN 1988 YAMAHA 150'S AND I WAS TOLD THAT I CAN CHANGE THE 2 OIL RINGS ON THE SHAFT IF I PULL THE SHAFT AND NOT THE BEARING. IS THIS TRUE, AND HOW DIFFICULT IS IT ?
rodbolt
Re: LOWER OIL RINGS
hello<br /> what are you attempting.<br /> from your description I am clueless.<br /> confused even<br /> so if you can clarify what your attempting I will attempt to help.<br /> good luck and keep posting
