Fellows.
this is johnson territory but. my 1957 6hp west bend needs propeller and dive shaftseals. can you reccomend the means of pulling out the seals without a seal puller as seen in the johnson manuels. the prop seal mounts flush in the carrier but the shaft seal under the impeller is recessed a bit. Any reccomendations for removal without the specialized tools would be appreciated. thanks Dom
