redgoat
- Joined
- May 23, 2010
- 102
Last summer I replaced a shift interrupter switch (39671A3) on my 153 cu.in. 120 hp 4cyl Mercruiser. I considered my self lucky to find this NLA part at a local dealership. This seemed to solve my forward to neutral binding up problem. My perennial problem for many years has been engine stalling when hot when I would shift from neutral to forward or neutral to reverse. The engine would die. It would usually start right up again but would die when put into gear. I tried increasing the idle speed on my carb to see if that would help get it into gear before it stalled. No luck. For what its worth, I have thoroughly rebuilt the carb, new fuel pump and fuel filter, new plug wires and plugs, new coil, double gasket on carb base, adjusted needle valves, and set timing. I am aware of heat soak so I run my blower constantly to remove hot air from engine compartment. This Mercruiser engine is 45 years old but has been meticulously maintained. Now my problem is more evident when I run engine on muffs at home after sitting for a couple of days. After starting I will put gear into reverse only to have the engine promptly die. A second try may result in the engine not dying. Forward is OK. Days later I did the same routine with someone moving the shifter to reverse while I watched the A Bracket and shift interrupt switch. It did move and everyone knows that the switch is not supposed to do this. The switch is for killing the engine briefly when moving from forward to neutral or reverse to neutral. Clearly the plastic roller was out of the V notch and ready to kill the engine. I have taken this boat to TWO repair shops and one said he could not find anything wrong short of a lake test and suggested I had bad gas. Another facility (authorized Sea Ray Dealer) said he could not find anything wrong either and that the shift cable was on specs. I feel that the problem must be something other than the shift interrupt switch because it has no problem killing my engine. My lower shift cable was replaced 5 years ago and the boat has seen minimal use in that seasonal time period. In reading some older threads ACHRIS stated that when a cable is sticky it can trip the switch and kill the engine and that is likely the first sign of a bad cable. Another mentioned something about interrupter springs being too weak. Also, someone cautioned against lubricating the cable as being a definite no no. Maybe mine was lubricated 5 years ago. This problem has to be solved as I am thoroughly frustrated and tired of being towed back to the dock with disappointed guests. The photo is my old style shift interrupt switch. What should I do next?
