Re: Lower shift cable for alpha 1
Thank you guys!<br />It was my first time doing the shift cable.<br />So, I wanted to make sure I got it correctly.<br /><br />I learned a few valuable lessons:
<br />1. DO NOT tighten clamps on the shift cable below prior to threading 9/16" into bellhousing. I tightened clamp and took a short break. Leter when I came back, I started threding the 9/16" and did not really understand why the nut is turning with such resistance
. Good thing I only turned it a few turns and did not try to thred it in all the way
. Cable below was not damaged, so I untightened the clamp and it turned itself right back to normal.
<br /><br />2. If not for you guys, I would not even bother replacing it myself. Combination of IBOATS forum and Merc. manual makes it possible to accomplish new things yourself. <br /><br />I would like to THANK YOU ALL!!! <br />Happy boating season
