Hi
I have a 2003 Maxum 1900SR with Mercruiser 5.0L Alpha engine. Recently my engine has been cutting out when shifting from forward to neutral and sometimes from reverse to neutral. Reading all the forums, it sounded like I needed to adjust my lower shift cable. I took both cables off, pushed the lower shift cable to engage the forward gear and measured between the ends and it measured 6 1/4 inches. Every video I saw said it should be 6 inches exactly, so I adjusted it to 6 inches, then adjusted the cable above it (sorry, don't know what it's called) to fit perfectly plus 4 turns of the plastic barrel, put everything back and tried it again. With the new adjustment, it would go into forward, but I could hear the gear was not fully engaged. You could hear a clanking noise as the rotor spun. So I took it apart again, adjusted back to 6 1/4 inches and forward engaged easily with no clanking noise from the rotor.
My question is, is a 6 1/4 inches measurement on the lower shift cable when pushed all the way forward OK, or should it be 6 inches and I also have to do some other adjustment so that I don't get that clanking noise when the rotor is spinning?
BTW, with the 6 inch and the 6 1/4 adjustment, the engine still cuts out when shifting from forward to neutral, so I'm sure I have to check the shift interrupter switch as well to see why it seems to stay open for too long. But first need to sort out the 6 1/4 vs 6 inch question.
