Re: Lower shift cable on Alpha 1
It's because of the ramps on the dog clutch faces, if you try shifting and the faces on the dog line up directly with the faces on the gear, all you'll achieve is a streched/broken cable. As rodbolt said, either the engine or the prop MUST be turning when selecting gears, that applies to either forward or reverse. You got lucky with forward because the faces on the dog are lining up with the 'depressions' in the gear, so it goes in ok.<br /><br />Try it with the engine running OR someone turning the prop in the opposite direction to the gear you're selecting. ie, turn the prop ccw while selecting forward and cw for reverse.<br /><br />Chris...........
