lower shift cable?
conron
I have a 86 starline with merc 120 and alpha 1...when I shift into gear the interrupt switch engages, forward and reverse. If I push slowly to forward it will go into gear but not if I go at an normal speed and it is dieing going into reverse every time. I dont know what it is but was thinking maybe the cable going from the mount on top of the engine going to the drive? What do you think??
Bt Doctur
Re: lower shift cable?
Good guess, sounds like a bad lower cable
conron
probably original...as is most stuff on this old vessel
