Lower Shift Rod Seal Replacement 89 Force 50
retrojeep
Can this seal be replaced with out taking the LU apart/or removing the lower shift rod? If the rod must come out, can you unscrew it gently and replace seal and then drop it back in with out cracking open the LU?
Thanks!
Retrojeep
