lower swivel pin removal 1986 alpha drive
lime4x4
How does the lower swivel pin get removed. I've downloaded the manual and all it says is to remove the cotter pin then remove the swivel pin.Does it just tap out?
ErieRon
Re: lower swivel pin removal 1986 alpha drive
Pretty sure that's just a pin...no threads. If it's stuck/corroded, soak it over night with PB blaster and be gentle. There isn't much stock there to be pounding on it.
cr2k
If all else fails heat the aluminum area around the pin, but not the pin itself.
then tapping it out.
