loco
- Joined
- Apr 25, 2010
- 154
Hi all,
I'm finding that the oil pressure reading on my old Penta gauges (1990's analogue gauges from an AQ205a) is reading lower than usual. It would previously be at the top of the green, and would then creep to be a little higher than max level at higher RPMs. The gauge now tends to sit vertically, still midway in the green, but clearly lower than it has been historically. The gauge does move as the revs fluctuate, so I'm sure there is still signal being sent.
That said, some of the wiring in the boat is coming up to 30 years old, so I would expect some voltage loss along the way.
It's got very fresh oil in the engine, and the engine only has ~150 hours on it, so is still quite young. However, I've had some issues this year when I overtightened the inlet manifold, resulting in water getting into the engine, but was all pumped out and has had two oil changes since replacing the gaskets.
So, I need to do some checks.
First up, the sender could be faulty. It's one of the old manual units like this one:
http://www.iboats.com/Sierra-18-5899...view_id.172098
What should the voltage from it be? does it just go from 0V for no pressure up to ~13V max pressure?
Secondly, I need to check voltage loss along the line, and maybe run a new cable to the gauge, just to test.
Alternatively, I think you can buy a manual pressure gauge to plug straight into where the sender is, so I can directly test the pressure. Does anyone know the gauge of the thread on the sender, so I can pick up an appropriate gauge?
Thanks in advance.
Thanks in advance.
