Re: lower unit 85hp johnson 75 yr
frontneck,<br /><br />Some movement is normal.<br /><br />I would suggest you replace the fill/drain plug seals, refill the unit and run it.<br /><br />Check it again after a few hours run time. If you have water again, you should have the lower unit pressure/vacuum tested.
