hello,i have a 1988 johnson 110hp vro.model#Jll0TLCCA serial#7814658.im trying to change waterpump,i have linkage disconnected from below carbs.also the four 9/16 side bolts on lower unit.the problem is i cant seem to get the 7/16 one on trim tab or the 5/8 one in front of it.they havent broken loose and i put pretty good pressure on them with a 3/8 rachet.im afraid i will brake them if i try harder
,any advice or tips?wd-40,heat(not good on alum.)im lost.thanks for any help.
