Alright folks, i got a late '60's early '70's LU off an L6 outboard and can't get that bearing carrier assembly out of there! The unit is locked-up (prop shaft and drive shaft). I removed the threaded locking ring that holds the carrier in place, then i made a thick shim from metal plates and a 4x4 put that down over the prop shaft and then put the prop nut back on the prop shaft (remember, it's locked) and tightened the prop nut until i was blue in the face! I tried tapping the housing with a rubber mallet with pressure applied to maybe dislodge it, but this booger just won't budge. I also tried heating the housing, not a lot, but i did apply some heat to see if that would help. Any suggestions or insight would be much appreciated.
