Lower unit compatibility
sksemke
Hello, I have a 1978 Evinrude 85HP. I would like to replace the lower unit, but I'm not sure what years and HP will be compatible with this moter. Any help would be greatly appreciated!!! Thanks!
tashasdaddy
Re: Lower unit compatibility
i believe 77 was the 1st year of the mechanical shift.
Dhadley
We're not so concerned with the style of the shifting but rather interchageability of the unit itself. A 20" 1977 140 unit will bolt up & work but you'll have to make some linkage changes at the powerhead. A unit from a 20" 1977 85 or 115 will not. Any 20" V4 lower unit from 1978 and newer will work. A lower unit from a 1978 & newer will work too but you'll have to take it apart to change the driveshaft unless it's new enough that it has the 2 piece shaft.
