lower unit compatibility
busted-bayliner
I have a 1989 125 force outboard motor that needs a lower unit. My question is will or are the shafts interchangeable from a 1987 my motor is black the 87 is white i was wondering if i can put my two piece shaft in the 87 any help would be appreciated
Frank Acampora
Re: lower unit compatibility
The two piece shaft can not be swapped into or onto the one piece shaft case. The gearcases are different. HOWEVER: If the shaft length is the same, the whole lower unit can be swapped
