I was out on the water yesterday at idle speed when my engine came to an abrupt stop. I started it back up and as soon as I put it into forward gear it stopped again. The prop seemed to be locked up, but eventually I was able to get it running by throttling up before shifting into gear, and I was able to make my way back 6 miles the dock.
Got back home and the first thing I did was drain the lower unit to look for metal. To my relief, there were no shavings though the oil was dirty. When I took off the prop it was another story altogether.
Ugh. That's a bolt stuck inside the prop.
So where would you go from here? Replace the prop? Replace entire lower unit? Everything still seems to be working now, but you know how that goes.
Motor is a 1988 25hp. E25RCCA.
