Last night I removed my lower unit in the attempt to hunt down a leaky seal and to inspect the impeller. Great news! Impeller looks brand spanking new!<br /><br />I cannot seem to remove the lower half of the lower unit to inspect the gears
. There appears to be only 2 studs that hold the lower to the upper. I removed the prop and the bearing carrier to gain access to the shorts stud, removed the nut and washer. I also removed the nut and washer from the long stud at the top of the upper half. The front of the unit is where the 2 halfs refuse to seperate.<br />I tried strategicly hammering on the top of the long stud to jar it loose. I even tried unsing an air chissle (surgically of course) and still no go.<br />I can pass a thin puddy knife from the rear of the unit to about halfway towards the front then it gets tight tight tight. <br /><br />Okay boys! Lets here what ya have to say!<br />Thanks
