Re: lower unit drain and refill--flush?
Motor boater bill, it's oil you're using in the lower unit, not grease. I just say this because someone might question whether you're indeed putting oil into it. It's a little heavier oil than automotive motor oil, or 2 cycle oil, about the same as what is called gear oil or gear lube in cars. But it's nowhere like grease.<br /><br />As to flushing. I have used regular motor oil or 2 cycle oil to flush out a lower unit, figuring that if it drained completely, any residual left over would be a meaninless amount when I refilled with lower unit lube. Or, if even that worries you, why not just fill it up with lower unit lube, maybe turn it over or run it a little (w/hose of course), then drain and refill with new lube? The amount of oil wasted will be very small. I can't see the reason to flush out with solvent (mineral spirits, etc).<br /><br />By the way, the sort of condition you have seen (contamination by water) is fairly common so it's not an unusual situation. Like the guy said, keep an eye on it - check it after the next run to see if it's getting conatminated quickly (in which case you probably want to find the problem). Good luck.
