miichael18
- Joined
- Mar 24, 2004
- 161
I was going to change the gear lube in my 1989 force 125 and the lower drain plug is a hex screw and its stripped out. So now i cant drain the lower unit. it has a fill hole and vent hoe up top for filling. I took both of these out and put my pump in the fill hole and pumped alot of the old gear lube out (which was black). All together i got about half a quart out of it. Will it be ok to just fill it up with fresh run it a few times then get out as much as i can and do it again? or are there any other way to get most of the lube out? I tried using a easy out tool to get the drain plug out but i stopped before i went in enough to damage the bolt and maybe take a chance on it leaking.
