lower unit drop
FLOATY
How many nuts should be removed on a 1988 L6 115hp on the lower unit.
I've removed the nut holding the trim tab on, also a hidden nut on the under side of the trim tab. I've loosened the two nuts on top of the cav plate but noticed their were two more nuts under the cav-plate. Do I loosen those also? I count six is that it? Also my LU is a cam-shift type 1 do I put the shifter in foward when dropping the LU? thanx bj
