Lower unit E88MSELSA is leaking
99z286spd
There was no fluid in the lower unit when i got the engine so i swapped the lower unit with my old engine's lower unit. I'd like to fix it myself. Could it be something as simple as a seal? It seams to be leaking from inside the hub area not from the shaft seal. Also, i took out the 4 bolts that hold it in but couldn't get the carrier out..... now the 4 bolts wont go back in??? what gives? when i spin the prop shaft it seems "rough" to spin it as my other one spins smooth. Maybe the bearings are bad?
The power head was mint and I got it for cheeeeep money so i figured it would be worth it. Does anyone want to rebuild it for me? I dont have the tools to do it myself or i would. I'd like to get it done soon cuz my beautiful BLUE e-rude looks funny with a OFF WHITE, corroded, chipped, broken skeg, lower unit.
Let me know what i should do
Thanks
Leon
