Evinrude model # 4932D, 1979 2 cyl/4 hp<br />I am about to replace the impeller. Should the water tube grommet also be replaced, as a matter of course, or only if damaged noticeably? And how do I get the prop off? Does it just pull off, after removing the cotter pin? It doesn't move on mine, and I didn't want to force it, if something else is holding it in place.<br />While I'm asking, is there a recommended motor oil and gear oil, other than the generic available? Thanks for any help.
