What is lower unit gear lube for? How do you know when to use it?
B Big-HE Petty Officer 2nd Class Joined Aug 3, 2002 Messages 102 Aug 15, 2002 #1 What is lower unit gear lube for? How do you know when to use it?
L Lugnut36 Seaman Joined Aug 14, 2002 Messages 70 Aug 15, 2002 #2 Re: Lower unit gear lube??? Lower gear unit is the "transmission" of the motor. There is usually 2 large screws on the side of the lower unit that give you access to it. I usually change mine anually along with checking it for water contamination.
