Lower unit gear lube???
Big-HE
What is lower unit gear lube for? How do you know when to use it?
wilde1j
Re: Lower unit gear lube???
The gearcase, it has moving parts, the lower unit (the fat thing above the skeg). Should be changed at least once a year, depending on useage.
Trevor
chang at least once a year <br />I would suggest using the merc High performance gear oil it will lube up to 75% water <br />its great stuff
