Lower unit gear mesh
Froghunter
Folks, I have 1987 Johnson 40 h.p. While in the process of servicing the water pump, I noticed that the bottom end of the driveshaft seems to be rubbing on the clutch dog. When turning the driveshaft by hand I can feel each tooth of the pinion and drive gear meshing. (feels course)If I pull the driveshaft up a very small amount while turning it, it now meshs smoothly. If this condition is due to wear, my question is what is the repair? Thank you.
MCM
Re: Lower unit gear mesh
Welcome to the forum Froghunter,<br /><br />With the L/U bolted up and the drive shaft re connected the slack may not be there to allow for the contact that's present when disconnected.<br /><br />Just a thought :)
R.Johnson
When you have the gearcase off, and turning the drive shaft free hand, you can feel the pinion gear seemingly slipping in, and out of engagement. If you try this on a dry gearcase, such as after a rebuild, and before filling with oil, this is very noticeable. Keep in mind, these are bevel gears. Under power, the pinion will have some upward force, but retained by the bearings, and bearing retainer. The proper shimming maintains the correct gear lash under power, so what you feel is normal.
rodbolt
what R.Johnson says. its rather normal. dont hunt for problems :) :) . enough will come along all by themselves.
Froghunter
Thanks for the info, as a first timer, I'm impressed. I received 3 replies within one day.<br />The info I received made good sense, thanks again. :)
