Re: lower unit help
on these motors you have to remove the power head from the lower motor leg and remove the flare from the upper end of the water tube. and you may want to check but i dont think that you have an impeller your power head is air cooled the lower motor leg is water cooled but the way that this works if this is the case is that water is forced up the water tube by forward motion not by a impeller:/
