I have discovered a crack in the lower unit housing of my 1980 J70ELCSA.
It is in the thin rear vertical portion above the gear case and the prop. I found it while flushing the motor at the end of vacation. Water was flushing through this vertical crack in the casting. I do not see any water in the gear case oil.
Can this crack be tig welded shut with aluminum rod?
Or is this the end of this lower unit?
ZEKE/440
ZEKE/440
