Lower Unit Installation
NealLauderman
Fellas,
Dont know if you remember but I took the lower unit off to replace the water pump a while back and then had to move so I never got to finish everything. Now I am back at it and I am having a hard time getting the lower unit back on. I am trying to do it by myself because I dont have anyone to help me and it seems like its getting stuck on something. It is about 3 inches from closing all the way correctly. From what I can see the water pump is going on the hole correctly and I can see the gear shift rod poking through the casing under the engine. Its just got about 3 inches to go.
Am I missing something?
ob
Re: Lower Unit Installation
Yes. You left out what engine you are working on.
dsinger
drive shaft not lines up move the fly wheel back and forth.
