I pulled the lower unit to replace the water pump. When I pulled the old water pump off it seemed like the seal on the upper bearing housing was bad, loose fit around the shaft. I drained the gear lube out and did not see any evidence of water. The amount of lube was very low. <br /><br />The drive shaft has a lot of side to side slop. Is this typicall or is it indicating a problem in the pinion assembly?<br /><br />Any advice would be helpfull.<br /><br />RHB
