Re: Lower Unit leak
There are 6 points for water intrusion.
1- shift rod screw - not likely, DO NOT remove it !!!
2- drain screw gasket
3- vent screw gasket
4- prop shaft seal
5- driveshaft seal
6- shift rod seal
I would replace the drain and vent screw gaskets and fill it with oil.
Test run it a time or two and see if you are still getting water in there.
If need be, get a manual (Clymer repair manual) and replace the seals. The shift rod and drive shaft seals are easy. The prop shaft seal can be a pain.
