Lower Unit Leaking oil/water
lp142
I replaced the impeller and all the gaskets, after I attached it back to the powerhead, I noticed it leaks oil/water where it attaches to the powerhead, when I took it apart there was no gasket and none came with the reubild kit, am I missing something, also the pee hole is not continuos rather is strong spurts but it spurts all the time. It's an 66 Model 1100 6 Cyl Inline.
Thanks
jebeebe
Re: Lower Unit Leaking oil/water
If you mean where it attatches to the lower leg, there is no gasket there. You shouldn't have had it apart at the powerhead. Sounds like maybe the exaust tube isn't aligned or the gasket at the bottom (thick rubber) is miss aligned or damaged. Take it apart and check it out again.
