Lower Unit Lub questions for 1975 Johnson 6 HP
Outboard Tex
After two years of storage I am returning my Jon boat and 1975 Johnson 6HP back to the water! Today, I drained the lower unit and the fluid was brown and seems in real good shape. I do not have a manual on refilling the lower unit and have two questions:
1. Can I use High Viscosity lower unit gear lub SAE 80W-90? If not, recommednations.
2. Do I fill it from the bottom screw laying the motor on the ground?
Thanks!
tx1961whaler
Re: Lower Unit Lub questions for 1975 Johnson 6 HP
1. 80W-90 is correct. The marine type is better because it has additives to handle water intrusion better
2. The motor is filled upright, like mounted on a boat. Remove both top and bottom screws (don't touch any phillips head screws).Fill it from the bottom until it squirts from the top vent .
jasper60103
Also, buy a couple new vent/fill plug nylon washers, they're cheap.
Outboard Tex
Thanks for the quick feedback and support on my servicing. I also changed out the 2 spark plugs today and looking forward to firing up the old dog!
Outboard Tex
Thanks for the washing tip...I'll take you up on that.
Outboard Tex
Mas
You may want to put some 2 stroke or fogging oil in the cylinders via the spark plug hole and hand crank the motor to give the cylinders some oil before firing her up.
MAS
Outboard Tex
MAS
Thanks for the feedback and the tip on the cylinder oil.
O.T.
tolbertn
Being the rookie that I am, i removed the philips head screw and cannot get it back in. What do I do??
