ptownmobber
- Joined
- Apr 3, 2006
- 22
1988 Rude 15 hp<br /><br />Ive been trying to work out some problems with my lower unit, specifically the prop-axle-thrust bushing fitting. The diagrams ive looked at tell me how it goes together but not up close and how tight everything fits. MY question is this:<br /><br />How far down the axle does the l/u lube travel? Is it blocked off by the back of the thrust bushing? Or does it travel up and around that and lube where the axle and the prop meet inside the prop bushing and is eventually blocked by the thrust washer at the end?<br /><br />I ask this because when i reassemble everything, the outside of my prop and bearing housing arn't flush. Theres about a 1/8" gap between them<br /><br />Looks like this profiled: <br /><br /> PROP____________ ________Bearing Housing<br /> I_I______<br /> I<br /> I<br /> I<br /> _I______<br /> -----------I I--------<br /> gap<br /><br /><br />ANY HELP IS MUCH APPRECIATED
