This problem started at the end of last summer and seems to be getting a little worse. Took it out over the weekend....
Mercruiser Alpha I Gen I on a 1987 Baja Sunsport, 350 I/O. Shifts into gear fine, runs fine, turns fine...without the noise you wouldnt notice anything being wrong.
Problem is at lower speeds when the wheel is turned all the way (left or right) there is a definite clicking/clunking sound coming from the lower unit. Only when wheel is all the way cranked in one direction. I can only notice it at lower speeds, but I think thats just because I cant hear it at higher speeds because of engine noise. Even at high speeds it turns just fine.
I was thinking maybe gimbal bearing or U-joint.....looking for input here.....
