Patty Pooh
- Joined
- Apr 15, 2003
- 90
I went to go change the lower unit oil and removed the vent& fill screws but removed the wrong screw for the drain. The drain plug was broke off so ididnt see it. I thought the drain was some a screwtype pin. The one that sits almost all the way to the bottom of the lower unit. When I relized it was thewrong one i put it back and it tightend right back up? The gearshift was in neutral and i tested the gearshift in buy movingit back and forth and i coulnt turn the proppeller by hand hen it was in gear. when in neutral i could spin it freely. Did i mess anything up? Can I use an easy out to get the bottom drain plug out? Any suggestions i really appreciateit? Thanks
