Hey guys,
I have a 1962 Evinrude selectric (electric shift) motor, 40 H.P model 35933. I did some extensive lower unit work last fall and happy to say the motor is running great! I have been out several times now, and I've checked the lower unit gear oil a few times just to make sure things are right with it. Today I drained the oil out to replace it with some fresh new oil. For no real reason except to just replace the old lube with new lube and check for metal shavings in the old stuff.
I filled the gear case as I should have, through the drain hole until I saw the new oil come out of the oil level hole above the drain hole. It came out, but my question is this. What is the listed lower gear case capacity for the oil? It took only 12 oz. to fill it completely and that does not seem like enough oil to me, but like I said, it came out of the top hole as I pumped new oil in SLOWLY. Wondering if the gear case is full or not??? Thanks for any replies!
