Lower unit oil for Mercruiser
dtholmanmax
went to boat shop to purchase a few things for my 91 Bayliner - has a 4cyl Mercruiser 3.0, Alpha 1 in it - and was going to pick up the oil for the lower unit. The guy told me that it was either Green or Brown and didn't know which to sell me because you can't mix the two. Is this true? I haven't checked it just yet but at the same time I've not seen anything regarding this issue, either. Please advise. What kind should I get, is one better than the other? Can I switch from one to the other and where should I get it?
lenny2113
Re: Lower unit oil for Mercruiser
"Quicksilver" lower unit gear lube - "green stuff". :)
WillyBWright
You can mix them, no problem. The good stuff is synthetic green, the regular stuff is dino brown. You don't need the good stuff for a 3L, but many shops only use the green stuff. No point in buying two barrels when all you need is one for everything from little outboards to bigblock sterndrives. It's a bit more expensive, but not prohibitively so. I think it's well worth it! :)
tommays
the better merc oil is well worth the money it stands up to water better than any oil i have seen <br /><br />tommays
dtholmanmax
Thanks, guys. How much should I purchase?<br /><br />David
Haut Medoc
It takes a little more than a quart. So get 2.
