lower unit oil
mark1rev
hi every 1 just changed oil on my 3cylinder 50 merc, the manual said 12.5 ounces of oil i can only get in 1 tube full the amount on tube is 225 grames.i have removed oil vent screw and filled as book suggests, oil is comming out top vent so might it have air in ?
AMD Rules
Re: lower unit oil
You're correct, the gear housing lubricant capacity is approximately 11.5 fl. oz. (340 ml). Are you sure you let it drain out completely prior to re-filling? You might try rotating the prop shaft, and tapping gently on the gearcase with a -soft- mallet to pursuade any entrapped air out the vent.
Is the gearcase sitting truly vertical? I'd let it rest for a while, and see if the air works its way out, allowing more lubricant to be added.
Seems odd you can only get 65% of the lubricant in there, unless it has an air pocket or was not completely empty, or was filled to quickly creating a lot of small bubbles in the lubricant.
If it is really cold where you are, the oil viscosity may be making it difficult to vent.... fill it -slowly- from the bottom.
Good luck.
mark1rev
Re: lower unit oil
shall i let it stand all night without vent screw in and try again in morning ?
i just sqweezes tube it took abou 2 miniuts to fill. maybe i done it to fast :redface:
Don S
Re: lower unit oil
Did you remove the vent plug when you drained it?
How many ounces is 225 grames? What's a gram???
It shouldn't take 2 minutes to put in the gear lube, What kind of gear lube did you use?
There could also be a slight difference in the amount it takes, just by the casting and machining process.
lure washer
Re: lower unit oil
Don S here are the conversion rates
1oz = 28.35grams
7.9oz = 225grams
mark1rev
Re: lower unit oil
think its ok now toped up next morning got half a second tube full in thanks every 1 for your fast replies:)
joed
Re: lower unit oil
Grams is a weight measure not a liquid volume. They don't really compare. Ounces as in weight(pounds) does not compare to ounces as in liquid either.
