I have a 1975 ,85 Hp,Sea Horse that runs beautiful.Can you tell me how to check the LUO?One more small item,has anyone noticed a buzzer that goes on periodically for some unknow reason?
there should be 2 screws on side of lower end open top one there the oil plugs bottom one is for filling it .Buzzer may be motor running hot check your cooling system
75 85hp, only has an overheat alarm. remove the bottom SLOTTED drain screw. if water comes first, you need to change the grease. you open the upper vent screw, then refill thru bottom hole, till grease is to the vent hole, close vent screw, then bottom school. everytime you remove these screws, replace the sealing washers.
