I just changed my lower unit oil for the first time myself..all the other times i took it to a shop. Right now it has about 325 hours on it and i had the 200 hr done at the shop. when i drained it...it started out golden and when the bowl that i drained it into filled up it looked greenish...is this normal? it didn't appear to be milky nor did i see much water at all come out of the lower unit. the other thing i noticed is on the top vent screw it had very very small particles of metal on the magnet but not too bad...bottom vent screw didn't have any particles(not sure that one is magnetic). should i be concerned with this or is it normal for a motor with 325 hrs on it. the unit must actually take more than a quart cause i ran out and have to get more of the yamaha gear lube to finish off the servicing tomorrow.
