Cricket Too
- Joined
- May 14, 2003
- 1,732
These are the drain plugs off of my '04 Evinrude 200's (FICHT). The first pic is the Stbd and the second 2 pics are the port side...I attached 2 for the port side since it looks worse than the Stbd..
Does this seem like an excessive amount of metal shavings on these plugs? This was the first time I've changed the lower unit oil since buying the boat, last year, so I don't know when the last time it was changed was....I'd hope every year, but this seems like a lot of shavings for the last 30hrs that I've run it, then again I've never owned engines this big before so maybe it's normal. It's not heavy chunks, it pretty much goes away when you rub it between your fingers but the port side definitely had some small metal pieces/flakes that didn't, but again not big chunks.
Stbd Plug
Port Plug
Stbd Plug
Port Plug
